12v to 24v shopping list?
Discussion in 'VR5, VR6 & Wx' started by 1990, Jan 19, 2011.
  1. Toyotec
    Mk 5 R32 is port injection, like MK3 R32 but the fuel supply to the injectors is returnless.
    The reason for the table is to show even if you physically plug in MK5 injectors running a MK4 ME7 control system with FPR rail, your ECU calculation for injection time from fuel flow will be off. This can be corrected but not with DIY knowledge.
  2. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    I got my loom and ECU today, the ECU is ME7.1.1, 022 906 032 CP, cost 110.
  3. 1990
    Rochdale, Lancs
    I've got some mk4 injectors now for a decent price (45.44 lasst second e-bay bid), I should get at least the same back for the mk5 ones
  4. 1990
    Rochdale, Lancs
    Got my engine today!!! Well chuft, it looks brand new. I met the guy at Hilton Park Service at birmingham and dragged it into my van (dont tell my boss)
    I've got a load of bits to sell now including KDP gearbox, starter, ECU, Loom, dual mass flywheel (would that sell 2nd hand at 20,000miles?), R32 PAS pump, 84,000mile VR6 engine, 6 branch. I'm hoping to get enough back to pay Andy for fitting it.
    Also wondering if the Mk5 downpipe and cats would sell for a decent price. Unsure weather to buy a dubpower manifold of modify the standard one, the flexis are very flexi.
    There a load of bits on the engine that I have no idea what it is, one thing seems to be a pump for the crankcase breather near the oil cooler, and a load of other plastic boxes here and there.
  5. 1990
    Rochdale, Lancs
    Heres a pic of the mk4 and mk5 injectors side by side. The mk4 ones are thicker and longer at the nozzle end but same size for the fuel rail and same plug for the wiring, I swapped mine over today from mk5 to mk4:
  6. 1990
    Rochdale, Lancs
    I now need to get rid of the air con pump and pully, what would replace it? My PAS pump needs to go there I think
  7. rubjonny
    could you not just convert cvar to non-ac spec? or was it always fitted as standard...
    if not then id assume you can use mk4 6pot lesser model bits, or maybe even vr6 stuff?
  8. 1990
    Rochdale, Lancs
    I think I need a v6 4 motion alternator bracket and PAS pully to mount/use my VR pas pump. but would also need a new belt I think.
  9. rubjonny
    bit o string method methinks :thumbup:
  10. 1990
    Rochdale, Lancs
    Any idea of the price of the pully and bracket from the dealers? I've been offerd both 2nd hand for 50 delivered.
  11. MUSHY 16V
    aberdeen
    50 to 70 for the bracket and about 20 for the pully you may have to add vat on that
  12. 1990
    Rochdale, Lancs
    I've had another bracket offerd to me for 20 and I can collect, its just the right size for the dishwasher.
    Will I also need the tensioner?
  13. rubjonny
    looking at etka for 2.8ltr AQP/AUE:
    022 260 087 - bracket for alternator (same for ac and non ac)
    022 145 299 D - tensioner
    066 145 933 K - v-belt non-ac, 21.36x1264mm
    does the MK5 have some kind of electronic PAS then?
  14. 1990
    Rochdale, Lancs
    Yes, and what I thought was a big pas pump is actually the air con :lol:
  15. rubjonny
    no wonder i couldnt find the pas system in etka then :lol:
  16. 1990
    Rochdale, Lancs
    I've got the bracket now but the thing I thought was a tensioner is actually just a roller I think.
    This is it (thats not jiz on my pants BTW):
    Is the 4motion tensioner same as the VR6 one?
  17. rubjonny
    is there a part number on it? doesnt look anything like the picture...
    the slotted holes look liek they are there to set the tension?
  18. 1990
    Rochdale, Lancs
    The only thing on it is: INA38317.
    The guy will swap it for me next time I pass.
  19. MUSHY 16V
    aberdeen
    john thats not the tensioner it is the relay roller
  20. MUSHY 16V
    aberdeen
    this is what you shoud end up with only with no aircon
    found this picture on another forum
    this is what they did on my 4motion
    not sure about the roller relay that you have in your picture
    i did see some thing like it but cant find it now
    http://uk-mkivs.net/forums/t/260410.aspx?PageIndex=10
