12v to 24v shopping list?
Discussion in 'VR5, VR6 & Wx' started by 1990, Jan 19, 2011.
  1. MUSHY 16V
    aberdeen
    r32 is 022253050C and 022253039E
  2. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Can someone send me the link to the 24v wiring diagrams please:o
    Edit- Forum Problems
  3. rubjonny
  4. mat-mk3
    Bristol
    Ah, I have elsa. Might have them anyway. Just find it hard to use:lol:
    Cheers J
  5. mat-mk3
    Bristol
    Did you use this belt in the end Ian?
    I need to remove the air con pump and fit the VR6 PAS pump and need a belt for it all[:s]
  6. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Thats what I have but its not bolted upto the engine yet. The tensioner was just 20 with CGTI discount from GSF
  7. G60KG
    G60KG Forum Member
    at work 'working'
    Jealous - searching eBay for r32 engine prices right after this post [:D]
  8. mat-mk3
    Bristol
    Good stuff. My engine is a standard 24V 4Motion so already has the bracket & tensioner. Just need the belt:thumbup:
    All i have to fit is the VR6 PAS pump[:D]
  9. mat-mk3
    Bristol
    Just found a handy little bolt hole in the top of the tensioner to put an M8 bolt in. Screw it so it pushes the wheel round and you are able to put the belt on & off:thumbup:
    Good design!
  10. MUSHY 16V
    aberdeen
    eye it's handy :thumbup:
  11. oburT6RV Forum Member
    Did you manage to find a part no for the pulley?
    038 145 255A is the p/n for the pump itself but so far I've not been able to get a number for the pulley!
  12. rubjonny
    that is the number for the pulley :) the pump is 1J0 422 154D
    the pulley looks to be the same as on other MK4 engine pas pumps, listed for loads o cars
  13. oburT6RV Forum Member
    Ah cool, thanks, I'll get one ordered!
  14. oburT6RV Forum Member
    Guys, are the AUE 2.8 and BDB 3.2 oil filter housings and filters the same?
    I'm cobbling together one working engine from the above 2 but my BDB didn't come with an oil filter housing. The AUE's housing bolts onto the 3.2 block no problem. The corn dog shaped filter I can't get my head round though. The bit inside the housing where the O ring on the filter slips into seems much bigger bore!? If that makes sense?
    12Vs were so much easier.
    Moral of the 24V story: Get a complete engine!!!
  15. MUSHY 16V
    aberdeen
    the filters and housings are diffrent
  16. oburT6RV Forum Member
    Quelle surprise!
    Off to ebay I go then. Thanks mate.
  17. oburT6RV Forum Member
    Brand new MK5 housing, comes with all O rings, filter and filter cap, 80 inc VAT. Pretty reasonable I thought.
    I needn't have bothered though because it's exactly the same inside as the 4Mo one.
    The O ring on the end of the filter appears to have no function! Suggestions on a post card.....
    [​IMG][/IMG]
  18. MUSHY 16V
    aberdeen
    The assembly number is different for both
    And you only get the part number for the housing up to 2001
    It's not that clear
    Aaaaaaaaa
  19. oburT6RV Forum Member
    The changes are very minor but that O ring on the filter intrigues me. The only thing I can think of is it's for the dealers when they do a service. Maybe they shove the thin end of the filter onto something whilst it drains?
    Or it's a generic filter for many engines and that O ring has no function on the R32? Doesn't matter either way, I'm just intrigued!
  20. murph81 Forum Member
    Republic of Ireland.
    Interesting reading!
    Is there any fuel pump and regulator combination that can be used so that mk5 injectors, rail and ecu can be kept?
