12v to 24v shopping list?
Discussion in 'VR5, VR6 & Wx' started by 1990, Jan 19, 2011.
  1. JWYATT Forum Member
    South Coast
    brilliant info there cheers ! , i got off the phone to storm the other night , they're talking about 1.6k four the emerald/modifed throttle body, and me sending both looms to them ,
    That would be open the parcel up and plug and play ... :p
    When i next speak to them i ask about using the mk2 clocks , i've seen how the 12vr6 is done with the resistors , just i really want to keep the mk2 clocks/16v 160mph coz those speeds would be more where its at on private roads though ,
    Jo :thumbup:
  2. Toyotec
    At that cost OE ECU and immo defeat is a bargin:thumbup:.
  3. prof Forum Addict
    Suffragette City
    that's bonkers, get a loom from andyout and run OEM
  4. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Or collect the parts and get Andy to do the whole conversion in 4/5 days. Thats what i'm going to do, if I did it myself it would take forever and probably never run or look right.
  5. prof Forum Addict
    Suffragette City
    great idea
  6. JWYATT Forum Member
    South Coast
    Thats 1.6k plus vat aswell !
    ,i've heard about andyout was going to drop him a call soon , but if i used the standard ECU and all that i've got alot of parts to source and would have to use the satndard clocks / throttle pedal setup wouldnt i ?
    Also the R32 engine im looking at has already had the loom to fit emerlad with the plug on the end .... ?
    I was half way through my VR6 ive got about 600 worth of VW parts like chains/oil pump/rings/bearings i was going to do full rebuild but now this R32 has came onto the table coz i thought well the money id be pouring into VR and getting best case just 1 or 2 over 200BHP .
    Its a real stuck in the middle , my tax rebate came in the post and premuim bonds just won a fair bit , i've been watching all the VR videos and think id be stupid to just stop this project coz its about 70% done. just to say im 18 and a mechanic apprentice i spend basically 99% of my wages on my mk2 , well what ever is left after rent/few simple bills ,
    Jo
  7. 1990
    Rochdale, Lancs
    Could anyone get me part numbers (and prices if i'm cheeky) for MK4 R32 injector rail and fuel pressure regulator?
    Thanks!!
  8. 1990
    Rochdale, Lancs
    Sounds like you would be better with the Emerald, some of the parts are proving very hard to find for the OEM setup.
  9. rubjonny
    022 133 317 F - BDE rail - 95.56+VAT
    037 133 035 C - BDE fpr - 70.97+VAT
    022 133 317 K - BFH,BML rail - 102.53+VAT
    078 133 534 C - BFH,BML fpr - 70.97+VAT
  10. Toyotec
    IMO that 1600 quid can be spent elsewhere.
    The other option if you must use a standalone is conventional cable throttle and stock pedal 1600 quid saved.
    There is a chap I know who has an Emerald controlled MK3 R32. Throttle is cable. MK3 clocks work as in any normal emerald conversion.
    The standalone will benefit, if you plan on making adjustments yourself. If not then good tuners know how to tweak both systems.
  11. JWYATT Forum Member
    South Coast
    i have to have a long think about all this ! :thumbup:
    If only Storms Wiring Diagrams were " freedom of Information " ;)
    Just a massive labour bill coz all the stuff they do i could here at home , just i dont have the info like them ,
    Jo
  12. MUSHY 16V
    aberdeen
    chears john for that :thumbup:
    this is what i am trying to do work out which wire goes to each pin on the ecu
    stole this picture
  13. Toyotec
    The connector is called 'T121' so say you wanted to connect the K line or data line to an OBD J1962 connector in a MK2 you will look for T121/43 ( engine control connector pin 43) on the diagram and connect to pin 7 on the J1962.
    EOBD, unlike OBD2 also comms by CAN and these can be found on T121/58 CAN-L and T121/60 CAN-H.
    CAN-H will connect to diagnositic connector (OBD/J1962) pin 6 and CAN-L pin 14.
    You can use that connector image and populate with a spreadsheet, using the Elsa pdfs John shared on page 2.
  14. MUSHY 16V
    aberdeen
    cheers will have a good look once the kids are asleep
    its not so bad for me as its a mk4 4motion i have
    i am only looking to change the ecu and engine loom
    i have the single coil pack on mine just now
  15. 1990
    Rochdale, Lancs
    Nice pic, I wonder how similar the R32 one is?
    And cheers for the part numbers RJ.
  16. MUSHY 16V
    aberdeen
  17. rubjonny
    have a look at my how to read vw wiring diagramsd guide as well. 1st time u see the vag diagrams it looks complicated, but once you get your head around how its laid out they're very simple to follow. though the older mitchel diagrams are very good too as they show the complete fusebox and all the traces inside it.
    main thing about mk4 over mk2/3 is they dont actually have a fusebox anymore in the strict sense of the word, they have 2 'racks' one for fuses and one for relays with the wires from everything just poking out the back
  18. 1990
    Rochdale, Lancs
    I've done my loom now, didn't need Andyout, I cut the wires and joined them nice and neat, loosely followed RJ's wiringdiagrams, should have it running in no time.
  19. JWYATT Forum Member
    South Coast
    nice ! :thumbup:
    Jo
  20. 1990
    Rochdale, Lancs
    Ha ha ha!!! Cheers!!
    I actuallly found that picture on another site, a guy had bought an unfinished project and had to bin the loom.
    Does anyone know the difference between the mk4 and mk5 wiring looms?
