OK, cheers. I'll get on the lookout for a mk4 loom and ECU. The other thing I'm wondering is can I use a V5 gearbox on the R32? Is there any benefit over using the VR box?
why the v5 box will that not be a pain with the mount are you not better using the vr box flywheel and clutch
FD in the VR5 gearbox is 3.9 with the same gear ratios as the CCM or even CDA. And R32 engine is capable of 240+lbft due to the engines sheer size. So if my recalibrated lard arsed 12v on the GS dyno can achieve near 190lbft and still shift the car on the original 3.39FD box, you can only imagine what a shot of 50lbft would do it it. Plus with 7000rpm on tap a car like this would make an easy 155mph+ bahn stormer.
I'm waiting on a photo so I can see exactly whats included with a 2007 BUB engine. Its advertised as complete engine box loom and ECU but i'd like to see it first. I'm thinking of the V5 box so I can sell my engine/box/loom and ecu as a complete package.
sounds much the same as what i got the loom was cut and i had no ecu but had the gearbox and diff i was 1800 for it delivered made about 500 selling the dsg gearbox no luck with the diff yet
Heres a pic of mine, no R32 badge though?? I think i'll get a 1.8 Auto badge to fill the gap, thats what the car was originally.
im sure i read somewhere you could fit a mk5 pump into mk3 tank or something, then the mk5 fuel rail cvan be used. or was that some wild fantasy made up in my brain
its the same as the one i got i changed the manifold to a mk4 one as mine had a broken clip i think that black bit comes off ie its only glued on what gearbox dose it have ps get your self on r32oc and get posting so you can sell all the spare parts you need 50 posts mind you i sold mine on hear and have two people after it
it would be handy if it did fit ps mine still has the mk5 fuel rail fitted but with the 4motion regulator plumped in you just take out the schrader valve out the end as mine had the wrong fuel rail and did not fit i will change it come time
i have any diagram you could possibly want from vw/seat from 93ish onwards! i did print out a BUB code diagram for 1990 if that was what you wanted? http://vwtech.no-ip.info/downloads/g4bubecupre06.pdf.pdf http://vwtech.no-ip.info/downloads/g4bubecu06on.pdf
Its a 6 speed, thats all I know. The photos I have are not the best quality, he took them on his phone
i am looking for a pinout for the ecu to engine and main loom on both a 2000 4motion and a 2003 mk4 r32 the plugs are diffrent i am looking into how i would rewire my loom to plug into a the later ecu the same pinout for the 3.2 audi tt about the same age would all so help cheers mushy
get me engine codes and i can track em all down for ya. if not i can make an educated guess but its easier with the codes
Should also be the same as the A3 3.2. Likewise I have these as well and can check later if John's ETOS/ELSAwin does not come up with anything. Might be helpful to get me an ECU part number, both Bosch and VW to aid inquires.
