'90 2l 16v(ABF) mk2 (restoration page9, going megasquirt), mk5 ed30
Discussion in 'Members Gallery' started by beetie, Apr 7, 2007.
  1. beetie
    beetie Forum Member
    leicester
    well went and picked up the new inner cv joint from the local gsf and yes it's the 8v gti one they have given me[xxx] as you may know they are smaller than 16v, g60 ones.
    might buy a lotto ticket, my luck has to change.
    my brother has helped me find the leak into the boot. i got into the boot while he sprayed water over the back of the car.
    the water is leaking through the washer nozzle. it's because the wiper arm has pushed it down (stupid lay flat rear wiper)
    i'll buy another nozzle and put the wiper back where vw intended.:thumbup:
    don't know why it gets to the side parts of the boot though[:s]
  2. beetie
    beetie Forum Member
    leicester
    well it's been back on the road for the last week and it feels quicker than ever.[:D]
    it's still been giving me some grief though.
    1. the throttle cable was sticking, although now it has been used a bit it has become better. will still change it.
    2. as the weather has been cold i have been getting so much condensation in the car, it was stupid.
    i figured i must have a leak somewhere, so the search began.
    sure enough a quick feel under the passenger sides carpets and the underlay was soaking.
    fed up of scraping the inside of my windows i took it all out to dry and removed the doorcard.
    resealed it all and did a guide for everyone too.
    http://www.clubgti.com/forum/showthread.php?p=1645761#post1645761
    after todays deluge the car is still dry:thumbup:
    3. the reason the headlining was peeling was because it was getting wet from the condensation dripping onto it from the roof. the headlining was now beyond repair. so i 'carefully' removed it[}:)]
    the condensation:o (bloody camera phone)
    so i now need
    a gti 3door headling,
    a bbs ra alloy, as i'm currently running with an odd steel wheel.
  3. i.a.n.b Forum Junkie
    Banbury
    At least its getting there.:lol:
  4. lord_sharpy Forum Member
    Near Leicester
    looking good mate, glad you kept the faith, i think we have all been there at some point.
  5. drunkenalan Paid Member Paid Member
    Leicester
    i thought i saw it this morning, good to see it progressing in the right direction too
  6. beetie
    beetie Forum Member
    leicester
    aye, even cleaned it on sunday. inside and out, including a good polish[:D]
  7. drunkenalan Paid Member Paid Member
    Leicester
    it always looks clean and polished!
  8. beetie
    beetie Forum Member
    leicester
    hadn't been cleaned since the trip to the ring in august.
    found out today it's still leaking[:x] . more condensation in the car.
    did a bit of investigating just now and the door seals aren't keeping the water out.
    plus i think that the roof gutter could do with being changed as the bit which butts up to the door has gone crusty (more exposed to the elements??) and doesn't actually seal to the door anymore.[8(]
    this results in more water than normal getting in the door area and allows it to get into the clamping part of the seal, and then into the car
    so the list now stands at:
    1 bbs ra
    1 3 door seal
    1 passenger 3 door roof gutter (plus a few clips to replace any broken ones)
    1 gti black headlining
    the carpet underlay
    don't know whether to go to the scrapyard, or to just buy a scrapper and junk what i don't need.
  9. ihaveajetta Forum Member
    northants
    if you are interested ill have a look at my seals and see if they are any good , you could have em if you want
  10. beetie
    beetie Forum Member
    leicester
    :thumbup: sweet, if you don't need 'em.
    think the main one though is that roof gutter thing. don't suppose you have a spare one of those.[:D]
  11. beetie
    beetie Forum Member
    leicester
    bbs RA alloy- check.
    turned up today from germany. will get the tyre put on at the weekend, and get that steelie off my car.[:D]
    getting there finally.
  12. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Do you know what underlay your going to use?
    Also about the leak, my van gets so much condensation in the back that it has its owm weather system.
  13. beetie
    beetie Forum Member
    leicester
    got the main bit completed this weekend.
    the bbs ra is now on the car:thumbup:
    and got the roof gutter sorted. got one from someone in cov who was breaking a mk2. also had a good chat about golf's, as you do[:D]
    after searching through threads about how to remove them i stumbled across posts by rubjonny(who else?) and stumc which revealed the answer.
    anyway on to the pics, and a quick Roof Gutter Removal Guide.
    first, cover a flatheaded screwdriver in masking tape to protect the paint.:thumbup:
    then lift the tailgate to get better access to the rear of the rubber strip. and prise upwards to pop it off it's clip
    now slot the screwdriver into the rubber channel and work your way forwards keeping tension on the rubber (to keep it straight.) by pulling it towards the rear of the car with your other hand.
    getting there
    you might have to lift the channel slightly and carefully to pop it off the the plastic clips.
    one of them off the car
    once at the front windscreen you simply pull it straight up in line with the angle of the windscreen.
    from here like so. (i stood on the sill to do this)
    all gone
    this is the metal strip you have to try not to bend. if it does get bent then they are apparently awkward to get on perfectly again. the metal part clips onto those plastic clips.
    the new one gets laid onto the car.
    windscreen bit first (tucked slightly into the wing) and make sure the the door seal bit finishes where it should.
    then just smack it home. working to the rear of the car.:thumbup:
    told you my old one was bad[xx(] proper crusty. hope to have a dry car now.
    next on the list is to still try and track down that '90spec headlining. and then i'm done.............till the next problem anyway.
  14. David Number 2 Forum Member
    Solihull/Coventry
    i tried to remove my lining afew months ago,
    failed miserably :| snap.
  15. RIP-MK3 Forum Addict
    sunbury on thames
    good to see the current problems are not engine related though!!! ABF FTW.....
    what happened to the RS's that were bought? presumably sold to recoup some of the lost from engine probs.....
  16. beetie
    beetie Forum Member
    leicester
    :o no way,
    the rs's are finished and sitting in the house ready to go on at the end of april. first show will more than likely be my favourite, stanford hall.
    i will put some pics on here though:thumbup:
    i am still searching for a decent headlining.
    i've also got a pic of the buckled ra[:^(] which i'll put up soon.
  17. beetie
    beetie Forum Member
    leicester
  18. beetie
    beetie Forum Member
    leicester
    well as the salt is now off the road i decided to get the new wheels onto the car.
    fully refurbed. keeping standard widths, as i don't want to cut my car up for some wheel to fit.
    centres are dark metallic grey powder coated. mirror polished outers with new bolts and nuts.
    brand new centre nuts with chrome badges for show days. the old center nuts with black centres for running around on
    with the chrome centres (on old nuts in this pic)
    on the car on the with black badges (pictures aren't very good[:$] ) i'll get some better ones soon
  19. i.a.n.b Forum Junkie
    Banbury
    Wheels look good, didn't see you yesterday!
  20. beetie
    beetie Forum Member
    leicester
    yeah sorry didn't think to come find you.
    will more than likely need some more parts soon though. want to get the rear beam done
