Converting wheel bolts to studs and nuts
Discussion in 'Track Prep & Tech' started by GVK, Apr 4, 2005.
  1. steve r
    steve r Forum Member
    i think they were called CF Fabrication. can't find the scrap of paper their details were written on, must have been thrown out [:$]
    A quick call to VW Racing should sort you out with their name/number
    CH Fabrication I guess.
    The Revo R32 has their studs on - checked last weekend, but seen before now. Looked fantastic to me. These are M14s though.
    Do yours have the first 5 or so threads missing? Shall have an eager look at the next NR...
  3. steve r
    CH fabrication sounds good, I think the guys name was Chris.
    yes mine have the first 4 or 5 threads removed, the end has been machined down into a dome so no sharpe edges and the nuts are lead on nicely.
    My main problem with them is that they were made from a pre threaded rod with the plain section in the middle just flattened down, they just bite into the hub due to the thread being flatttened but if you wind them hard enough they would go right through the hub.
    I would have preferred them to have been made from an oversive bar with the thread cut into it and the plain section left oversize so that when you wind them into the hub you get a positive stop and the stud locks in place.
  4. GVK
    Yep, same problem here (obviously)
    With the price of them I hoped they would have come machined as Steve describes above.
    As they are they aren't much better than Grayston studs but were a lot more dollar!
  5. altern8 Forum Junkie
    Cocos (Keeling) Islands
    how have yours been since you fitted them gary
  6. GVK
    Rusty.[xx(]
  7. Yoof Forum Member
    Sorry to drag this up again, what was the general opinion of these items from rallynuts.com:
    Only 1.65 each is appealing to my student pocket too...
  8. Dub Nutta Forum Member
    Gold Coast - Australia
    They're fine for the rear drums or discs, you will need to drill the threads out and spot face the rear so thay have somewhere flat to seat on.
    Ther's not enougth meat IMO to safely drill the front hubs out to use these. I used graystone Studs and welded the back of the studs to stop them from coming out.
  9. Yoof Forum Member
    think i'll get a full set of the graystone ones and just put a couple of spot welds on the back of each of them, then if i strip them won't be hard to replace, and will mean they stay there.
    Cheers for the advice.
  10. GVK
    Bump for Sparrow.
  11. GVK
    Pics
  12. pascal77uk Paid Member Paid Member
    Chelt
    i bought some grayston ones recently from demon tweeks then sent them back the quality was so poor. the mk5's have the proper quality ones with a lip, but they came with the big brake conversion, going to get a engeering compamy to make some proper ones
  13. sparrow Paid Member Paid Member
    Leamington Spa
    I'm speaking to a friend in South Africa about making some up. If the prices work out, I'll organise a group buy.
  14. Dub20vt Forum Member
    Somerset
    i'm currently considering a set, was going to make do with graystons n then weld the backs [:s]
  15. DAVE 2227 Forum Junkie
    As stated before ,rolled threads not cut threads if anyone is considering making some.
  16. Dub20vt Forum Member
    Somerset
    dave how are rolled threads formed? [:s]
  17. DAVE 2227 Forum Junkie
    Rolled threads are ,hard to explain btw, aren`t cut into bar but the dies form a thread by pushing into it.
    There will be no material removed in doing so.Cut threads remove material and create potential weak points in root of thread.You can usually tell if thread is rolled as unthreaded part will be smaller diameter than the thread and a cut thread tends to be more "sharper" looking in comparison.
    A better description.
  18. Dub20vt Forum Member
    Somerset
    ah i see the picture in the link said it all. Thanks :)
  19. sparrow Paid Member Paid Member
    Leamington Spa
    Here is a diagram of what I'm being quoted on.
    Any ideas/suggestions welcomed.
    I'll check the Grayston dimensions for the rear portion length.
    Front end, it's just a question of if people plan to run spacers and wheel hub thicknesses
