Ebay / VMI Forged Conrods & Bolts. Never again..... !
Discussion in 'Engines' started by Nige, Sep 3, 2014.
  1. fasteddie
    fasteddie Banned
    I know the time and money to build a good engine and 195 for a set of rods ....You just know its going to all end in tears :cry:
    Yes..... suck it and see on a budget build, would not be me ....but as already stated with Standard rods you know their limits and either build/map to suit
    or spend the money and get the right bits ....build it once-build it right ;)
    A.N. Other likes this.
  2. Toyotec
    The OE rod is designed to be durable over 100k miles without warranty issues and to reduce friction for better CO2. Those are just some reasons why the OEM is willing to pay and justify the extra manufacturing cost to have that hole to the gudgeon pin.
    There are durability benefits for engines used for endurance or extensive track use as well which is what appealed to Nige.
    It is an option though for IE rods and if you are not that fussed about long term durability it will still work:thumbup:. I also have a guys with 700bhp+ street legal drag cars with Eagle I beam jobs, without the rifle drilling and no problems.
    Nige likes this.
  3. sambo Paid Member Paid Member
    This is exactly why I have gone WITH riffle drilled option on my IE rods when i put my 1.8T engine together(present one in Lupo), as i knew i will be asking for big revs from this engine and also sustained at that when on track.
    Nige likes this.
  4. tshirt2k
    tshirt2k Forum Junkie
    Herts
    A forum trader on here, I hear won't supply rods without drilling. I think he should know his stuff.
  5. sambo Paid Member Paid Member
    It must help with longevity of small ends for BIG miles as extra oil can only help things that's for sure :)
  6. tshirt2k
    Herts
    LCR owners have developed small end rattles. Which points to wear through lack of lubrication. Not ideal for extra hot pistons doing hard laps on track.
    Makes me think about Brian's comment on small end seizure? [emoji57]
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Can anyone say for absolute certainty what the engine failure root cause was [:?:]
  8. sambo Paid Member Paid Member
    All guess work so far i think
    Does Abf have oil squirters in the block?
  9. tshirt2k
    Herts
    Yes
    Nige likes this.
  10. nut 20v
    nut 20v CGTI Regional Host - Birmingham & Midlands
    Overtaking you
    cant the other 6 bolts be sent off for tensile testing to see if if there even close to ARP spec's, then this might show a little light on the root cause of the failure?
  11. vw_singh Events Team Paid Member
    Well if anyone is interested in 3 left over VMI rods and bolts for testing let me know. I had the Rod from Cyl 1 let go on sunday :cry::cry::cry::cry:
    I was on my way to the Westside show on Sunday and dropped to 2nd gear at around 5krpm and gave it a boot full on the lowest setting of 0.8bar boost. Revs rose for a split second before a large bang and sounds of a gravelly nature while I pulled over to inspect the damage. Holes in the block and I can clearly see a broken rod bolt through the hole. The engine was still running on 3 cyl when I keyed off. Inspection to follow when it doesn't incur a family time penalty. [8(]
    History. Low mileage (40-50K) engine with a thorough strip down and cleanse. All plastigauged during assembly.
    That's Me and Nige with pretty much the same failure from same part. I'll know for certain when it comes apart.
    Gurds
    Nige, 51ngh and A.N. Other like this.
  12. EZ_Pete
    EZ_Pete Forum Junkie
    Under Bonnet, nr Abingdon
    :cry: Sorry to hear this.
    How about another forum whip-round to fund any such testing?; I'd be happy to contribute.
  13. Richard Mk2
    London / Bucks
    Sorry to hear that Gurds :(
    I thought I didn't see your Mk1 at the Westside show yesterday !
  14. sparrow Paid Member Paid Member
    Leamington Spa
    Noooo. Sorry to hear Gurds. Original bolts, or ARPs?
  15. Toyotec
    Bolts and rods same as Nige's [8(]
  16. tshirt2k
    Herts
    Oh dear!! [emoji21] Maybe they would be ok with better bolts? But doubt anyone would want to try.
    Nige likes this.
  17. vw_singh Events Team Paid Member
    Same as Nige's setup. I was in the USA when Nige's ones failed so I purchased some ARP2000s while there. I hadn't got round to fitting them and was planning on swapping them out before the next track day. Didn't think that local road driving wouldn't really be an issue.
    Gurds
  18. dUff
    dUff Administrator Admin
    Everybody Offline - looking good
    gutted for you Gurds , bad times
  19. Sirguydo
    Bolton
    Ouch :cry:sorry to hear this Gurds :cry:
    Hope you get sorted soon:thumbup:
    Where you are you going to make donnington ?[:s]
  20. Prawn Forum Member
    Oh Gurds,
    that really is properly **** news mate! I am so sorry to hear it :(
