Lightweight Mk1 'multi use' competition car. Various pics, testing technology
Discussion in 'Track Prep & Tech' started by Jon Olds, Dec 22, 2014.
  1. Jon Olds Forum Junkie
    thanks guys. super sunny day, car going well, was running in class 1B by mistake.
    corrected this to 3B after the heats and came second to car 73 by just under 0.1 seconds.
    all in all a great day, burnt petrol and rubber, nothing else
    there probably was another 0.2 or 0.3 available if I had got it bang on every corner, but I doubt it would go much quicker, as I was using all the revs/gears/brakes/track/kerbs, etc. (tyres took a right pasting)
    Jon
    Sirguydo, jamesa, RobT and 1 other person like this.
  2. Jon Olds Forum Junkie
    16V/ABF/KR head on 45's: mk1 is in mid rebuild, last event on grass 18th October. fitting the longer inlet manifold and 45's means the K&N's are just inside the front panel. phew.
    Unfortunately, there is no room for a radiator underneath the filters, so I need to find a 14" square one to sit in front of the gearbox.
    What do you guys use?
    Heard corsa and Honda may fit, but short on time so need to get a specific one ordered.
    help appreciated
    Jon
  3. Jon Olds Forum Junkie
    Found a 'geo metro' one about the right size, in 40mm thick ali.
    Going to give it a shot.
    65 ebay, so not much to 'invest'
    Jon
  4. Toyotec
    Corsa one maybe ****e, or at least the last time fitted one.
    I have a Honda Civic Ally job from e bay should do the trick!
  5. Jon Olds Forum Junkie
    thanks, I have gone down the semi custom radiator route. Think I need to post a few pictures to show progress, now its looking a little less 'used'.
    The top rad water takeoff is now off the end of the head, as per HPR recommendation. I am presuming the header tank is piped to one of the two side water pump 1" outlets and the other is blanked. That's tomorrows first job.
    Jon
    Toyotec likes this.
  6. Toyotec
    Custom rad even better!
  7. Jon Olds Forum Junkie
  8. MUSHY 16V
    aberdeen
    Ah that's what the manifolds were for nice
    what dizzy you using pug?
  9. Jon Olds Forum Junkie
    Luminition guts with clockwork advance, in a vw body. Yes, they have been gathering dust for a while. Just need another set for the mk2 now.
    Jon
  10. Toyotec
    That rad looks pretty adequate and a good fit. Are you going to add some sort of plate to keep the air flow into and out of the rad separated from the carbs?
  11. Jon Olds Forum Junkie
    Rad isn't ideal, but front end packaging on a mk1 is very tight.
    Not sure I have space for much air deflection, but I 100% hear where you are coming from.
    I envy the early scirroco's for all that space behind the nose
    Jon
  12. Notso Swift Forum Member
    Ducting around the radiator is critically important, even if it is only a 1 inch stack
    Hot exit air isn't really as big a deal as a lot of people make out, of course it isn't ideal but compared to having air hit the radiator and spill around it without actually cool the car will often see a lot of cars with radiators 20% bigger than they need with all the weight and packaging that comes with. Probably one of the most common errors with modified cars, and something you will never see left off a pro built race car
    Mk1's are great compared to a lot of moderns!
  13. Jon Olds Forum Junkie
    'Race car aerodynamics' great book. If I could only use 20% of its content. Agreed, with Mr Swift. Never had any real cooling probs with the mk1. Put this down to 'full radiator syndrome' (continuous 6mm bleed back to header). If only other makers could follow this.
    Still love a mk1, mostly due to its light weight and lift off oversteer.
    Jon
  14. sports racer Forum Member
    Australia
    If it overheats the standard radiator off a 1993 Holden Barina sits nicely under the slam panel. Not sure what the Barina was called in your part of the world but being a GM product (Vauxhall/Holden/Opel) they shouldn't be too hard to track down.
    Cheers
    Paul
    blis likes this.
  15. Jon Olds Forum Junkie
    Nice mk1.
    Aussy weather can be a lot hotter than ours, depending on where you are.
    We rarely see 20C+!.
    Short inlet manifold and short trumpets/no filters and it looks like you have loads of room.
    Mine is out competing (racing on grass) tomorrow, so we'll see what happens
    Jon
  16. Notso Swift Forum Member
    Not sure if the are the GM ones but the Suzuki Swift
    The GM (Corsa style) didn't come to Australia untill the the bubble styled one
  17. blis Forum Member
    New South Wales
    Sport Racer, there's a MK2 radiator (675mm) that's got the supply port that hits the AC on mine here if you need it.
  18. sports racer Forum Member
    Australia
    Thanks but my MK2 is a write off and doesn't need parts. The MK1 will get it's engine, brakes and dash, it doesn't need anything else. PM me if you need parts for yours.
    Cheers and sorry for hijacking this topic.
    Paul
  19. Toyotec
    Swift and Corsa radiator maybe to small for Jon is doing.
  20. Jon Olds Forum Junkie
    Thanks Toyo. I'm thinking going to a (relatively) lean mixture may be a contributing factor also.
    So hard guestimating jets without RR.
    I need a trackday or two with this.
    Wishing I had tried some bigger main jets, but its hard to do everything while trying to compete
    Jon
    Hoping HPR will comment on the end exit head system, as I'm really not convinced....
