Toyotec's How to install an ABF engine in your Mk2 Golf. Revisit of KJet car 180610
Discussion in '16-valve' started by Toyotec, Jul 4, 2007.
Tags:
  1. beetie
    beetie Forum Member
    leicester
    It's the belt that has the grooves, which then make the pulley 'look' like it's grooved.
    So you have the right pulley
  2. Nightroamer Forum Member
    Ah of thanks beetie. There appear to be some genuine groves ones in some pictures via Google but that said they could be pics of anything in reality.
  3. rubjonny
    yeah as above the pulleys start off totally smooth when new, then over the years the belt will gradually wear grooves in the paint :)
  4. Nightroamer Forum Member
    Excellent thanks gents
  5. Nightroamer Forum Member
    Morning all. Need a little help identifying wires this morning now the engines in.
    I have a 2 pin plug with green/yellow and black/white wires
    A 2 pin plug with white/yellow brown/blue
    A 2 pin plug green/grey and grey/green
    Also have a single wire purple/white with no plug.
    Thanks gents
    1. carbon canister -> bin
    2. outside air temp sensor -> bin and use mk2 outside temp sensor wiring (if fitted, its for MFA dash)
    3. sounds like aircon, is it near ecu? all aircon wiring -> bin
    4. fusebox area? MK3 clocks mpg signal from ecu -> bin
  7. Nightroamer Forum Member
    Thanks rj. As for the outside air temp this seems to be elsewhere as it still has the sensor on, was going to chop off and solder mk2 wiring.
    Currently , seem to have no wiring for intake air temp and 2 pin coolant sensor. Any idea on the colour for these
  8. rubjonny
    the 2 pin white sender in the head is for the ecu, brown/blue and brown/white. outside temp is yellow/white (sometimes blue/white on seat looms) and brown/white it should be in with the lambda probe and outside temp wiring
    oops got #2 wrong, thats your IAT sensor, the mfa outside temp is red/white and brown/white, my bad!
  9. Nightroamer Forum Member
    Thanks matey I will have another look tonight
  10. Nightroamer Forum Member
    Hi buddy.
    Had another look tonight picture below shows current setup.
    Back to front shows single wire connector yellow/red then 2 pin connector in flange has no wires, then 2 pin plug on head has brown/green and brown /white.
    Any idea what's what and what's missing?
    Also have single blue wire near reverse light switch which I assume is alternator and a large 2 pin plug with brown/red and blue/red is this defunct my coolant level?
    Thanks loads
  11. Nightroamer Forum Member
    There are 2 X 2 pin plugs in the loom round the back of the head also. One is black and brown the other is grey/yellow and brown/white.
    Sorry for all the questions but the loom was a state
  12. rubjonny
    2 pin in side flange is for aircon, dont need it. you can fit non-ac mk2/corrado 16v or abf flange if you want to get shot of it or just leave it as is.
    the black and brown 2 pin is for the breather heater, that does nothing and pops on a moulded plug connector on breather pipe but you'll see it has no pins in. the other one is the idle switch, pops on the back of the throttle body.
    i just chop the breather heater wiring out on my looms while im repairign the tps and idle switch wiring :)
  13. bbs_rs New Member
    Hey guys,
    I bought a 9A engine and want to swap it into my MK1.
    Currently it's running a PL engine with the KE Jetronic (CIS-E) instead of the regular KJet.
    Can the 9A also run decently/"plug and play" on the KE jetronic system?
    Thanks! :)
  14. Toyotec
    Yes it can.
  15. bbs_rs New Member
    Thanks Toyotec.
  16. ruzzell
    ruzzell New Member
    cardiff
    Looking to megasquirt in next few months, Can u use the abf dizzy hall sender for megasquirt or do u have to use a kr one? Because of the dizzy window, have had a good search but found nothing definitive. Thanks
  17. Toyotec
    The ABF Dizzy is a cylinder recognition sensor, where as the KR/9A/6A Dizzy is the engine speed generator.
    The latter has 4 windows as opposed to 1.
    ruzzell likes this.
  18. ruzzell
    ruzzell New Member
    cardiff
  19. Nightroamer Forum Member
    Big thanks to Toyotec for the amazing guide and both him and Rubjonny for answering all my questions on here. My 8v ce2 car has just had a 205 mile test from home to Santa Pod and back with the new ABF and it was perfect. Well worth the effort, the drive is so different just epic fun! Thanks again
    rubjonny likes this.
  20. NevzzMk2 New Member
    Sorry if this has already been awnsered, ive got aMk2 1.6 driver, and have a ABF engine block ready to go in, but i need a new loom for the ABF, wondering how hard its going to be to install the ABF in the Driver, ? look like putting the engine in is easy but the wiring will be a pain?
    also do you do these as a side job ? want to do mine for me ? haha
