Tubular seat rail installation
Discussion in 'Track Prep & Tech' started by A.N. Other, Aug 14, 2006.
    From PM:
    Tube was CDS ie seamless, 38mm, 12 guage, 13.50+VAT, from Merlin Motorsport, Combe.
    Can someone translate 12 guage into mm? Alien to me...
    Just to pick up on the crotch strap mounting mentioned in the thread, this was a decent Mk4 Golf DTM car - captive threads for crotch strap just visible on rear seat rail:
  2. Dub20vt Forum Member
    Somerset
    12 gauge is approxamately 2mm chris. Might be worth double checking with a zeus book though [:$]
  3. IanCarvell Forum Member
    Chris, you dont usually put spreader plates on the tunnel side of the seat tubes.
    The theory is that when you have a "visitor" coming into your door at a fair rate of knots the tubes intentionally punch thier way into the tunnel so the driver moves with the shunt away from the incident.
    Nice job though...did you do your own welding?
  4. TrackCab16v Forum Member
    Wales
    top job chris
    Ah, interesting point. I'd broadly copied what I'd seen around the VW paddock and WRC/S1600 cars, but I must check whether the inner rails were backplated. The BBT R32 was one I looked at a lot.
    I've just had a look at the SBG/Schmidt Golf over on here and I think it has plates on the tunnel (p. 31), but maybe as with the cage design, that the thinking has moved on over the years?
    I guess the flipside is whether a rail is as well tied into the tunnel on a roll, without the backplate?
    My welding [:$] done in the run up to the '06 'Ring trip. Finally got to grips (I think!) with just 'spotting' a MIG, after much studying of the appearance of welds on the S1600 Fiesta at Autosport '06.
  6. IanCarvell Forum Member
    If you look at the Mk2 Grp.A picture on page 135....they have spreaders on the sill side but not on the tunnel.
  7. A.N. Other Banned after significant club disruption Dec 5th 2
    Yep, indeed [:s] There must be some difference of views on this (I wasn't aware!) since here's the Wood-Scott Mk4 Golf GT car, which presumably was done by ART?
    Anyway, seems we've unearthed a bigger reason to get those OE seat rails out, which is why this forum melting pot is so good [:D]
    Edit: Neuhoff Diesel Mk4 Golf just checked and, yep it has them [:s]
  8. PhatVR6 Forum Junkie
    I thought that car was built by Frazero?
  9. A.N. Other Banned after significant club disruption Dec 5th 2
    Ahh, yep, think it was.
    Edit: ART claim shell prep in a Golf article! [:s]
    :lol:
  10. DEX
    Dex Paid Member Paid Member
    IIRC 16 Gauge is 1.6mm, so 14 Gauge is 1.8mm, so 12 Gauge would be 2mm
  11. Dub20vt Forum Member
    Somerset
    woohoo my guess on the last page was right then. Good job really as i've just aquired some :lol:
  12. Yoof Forum Member
    16 gauge = 1.6129mm
    14 gauge = 1.9939mm
    12 gauge = 2.7534mm
    10 gauge =3.5103mm
    8 gauge = 4.2697mm
    Hope that helps.
    Cheers
    Yoof
  13. Briankl Forum Member
    Denmark
    Spreader plates on seat rails are actually required here in Denmark according to the national motorsports association.
    The idea of letting the seat rail punch through the sill and/or tunnel doesn't really appeal to me, because that'll mean that the seat is loose inside the cockpit, and you harness is in no shape to do what it is supposed to do. It really requires your seat to be stationary to keep you tight against it as to avoid back injury and such.
  14. stephcasscar Paid Member Paid Member
    Great thread, a very interesting read,
    The seat rails I made in the Jetta were a bolted down box type, but a botch compared to that tubular set up[:$]
    I think I'll use the tubular set up from now on.
  15. gillm
    gillm ***** User
    yeovil somerset
    nice job mate hope mine turn out like those
  16. gillm
    gillm ***** User
    yeovil somerset
    just started to do this on my mk1 . but slightly diffrent .
    gona to be using 2by1" box section with nuts welded inside the to allow the seats to be bolted down . also im gona put a hole in the raer of the front section and the front of the rear section so if the nuts come lose i can fit new ones .
    i have removed the 2 side runners today but im leaving the front as i dont need it moved as im long legged , plus it will give it more strength (and less work :) )
    gona do a bit more next week as im on lates this week but i hope to have some plates and the box section in by this time next week .
    put the seat in and played hanger pilot for 5 mins too which boosted my moral in the car lol
  17. gillm
    gillm ***** User
    yeovil somerset
    did abit more yesterday .
    stripped back the sound proofing and removed the passenger side and made up so plates to cover up where the rails were .
    quick question tho .
    what is the disc that is on the floor ? mine is covered in some white sealent and is a pig to get off (the sealent)
    i will get some pics up soon
  18. A.N. Other Banned after significant club disruption Dec 5th 2
    Leave the discs in imo - they're only from where access holes were put whilst the shells are welded/assembled together (I assume).
    You'll only have to bond / tag them back in.
  19. gillm
    gillm ***** User
    yeovil somerset
    yeh im going to leave them in but its the sealent around them im trying to remove/tidy up .
  20. gillm
    gillm ***** User
    yeovil somerset
    all the rails are out and the bars are cut to length im just waiting to weld in the new plates and bars (plates not shown )
