starting with a stock driveshaft would make everything easier, so VR I guess, mk4 are probably too long unless running porsche offset type wheels
Bugger, didn't see that advertin the classifieds! Roxylife's thread when it all got put together: Ball joint extenders (REVIEW) + Compbrake tie rod ends fitting Sean, bottom of page 1 G mentions about machining down a standard inner CV to create a spacer. Sounds like a good idea to me, although they are quite heavy as standard? The Roma one looks as though it has the lip of a drive flange welded to the spacer to accept the inner CV from the driveshaft, to keep it in check perhaps.
Driveshafts are something I will be looking at soon. I will probably use a method similar to the blue Roma tuning car or source longer shafts. Prof, I might take a look at your leads. Thanks. Bumpsteer might only be a problem if I use the ball joint extenders otherwise the new tie rod ends will sit at the stock position. Chris, I have some ball joint extenders that will probably mess up the OE bumpsteer. Gurds
I think there is some confusion here. The pics don't show it but Gurds said he was fitting ball joint extenders too which would change the arc the wishbone moves in with compression and droop. If this arc is different to the arc of the steering arm then you'll get bump steer. Sorry if I've explained something you already know EDIT: Just seen G's reply.
found these,911 adj bump steer kit,pics might be of use,link. http://www.gprparts.com/brands/rsrProducts/
Gurds i hope you don't mind but i brightened up your pics (ignore this as my monitor was playing up): I am probably being dumb Gurd's but how do your drive shafts still reach at the moment? seanlazyass that drive shaft extender was on the 1st page (GVK mentions it). EDIT: noticed the link i had to the pic was removed at their end.....Oops
No problem Sean. The driveshafts have not been offered up yet. I need to complete the headwork and get the engine and g'box back in the car before I start playing with driveshafts. With normal track width and neg camber, I used to break lots of short side inner cv joints. I found that the joint centre was making contact with the diff cup seal thus implying the standard mk1 gti shaft is too long when the car is lowered and lots of neg' camber. So I want to see where the same shaft sits on the new setup then see how much spacing will be required. The long side drive shaft will need to be spaced. Gurds
Cannot find anyone on there under that name? http://forums.vwvortex.com/zerouser?cmd=viewactive&sort=1
I think Prof means X-KROM-X or something. Look for a thread called "ultimate driveline" in the tech/16v area and you will find his posts. Gurds
Found it: http://forums.vwvortex.com/zerothread?id=2681754 also came across this top mount (rabbit?): http://i123.photobucket.com/albums/o314/Rabbit051977/RabittParts005.jpg
Mr Hillclimber do you use any kind of ARB's on the front? The ends on my Eibach at the moment finish half way across the top of the wish bones.
Rabbit/Mk1 towers with Shine/Eurosport camber plates. No track width gain there - just spherical tops.
^ ^ ^ anti roll bar Looks like there's a smallish anti roll bar fitted in this pic - the angled bar that runs between A arm and steering arm - mounts further along the front tube of the a arm - looks like an arb to me mike . Been chatting with some road rally guys today (one runs a mk1 gti) he was going on about not having an uprated front arb (he runs standard front , large neuspeed rear) as the general feeling amongst his friends is that a smaller front arb gives better turn in , some even went as far as not running a front at all . They then confused me even more by saying that they then lower the spring poundage to compensate , i'd have though no antiroll bar would mean an increase in spring poundage ? , rear bar should be an uprated item though . Dont mean to hijack your thread mike but can anyone confirm the above , sort of related anyway to track day cars --- ish .
For longer steering arms on my mk1 i used mk2 non power steering tie rods and ball joints. This gave me around 30mm extra each side. they fit straight on to mk1 racks. As far as drive shafts go. id look at getting some larger outer cv joints on there to make them stronger. What about fitting a roll cage that gets welded up to the front turrets with plenty of cross braces. and get a auto cavan style lower front strut brace. Definlty look at bracing up your steering rack mounts Then stick on some wheel spacers and see how it goes
Not sure if 30mm will be enough for me & if your going to the trouble of extending everything then spacers should if needed be very small.. Rack mounts are strengthened on mine. http://img.photobucket.com/albums/v90/fthaimike/Track%20Car/DCP_6188s.jpg but another place woth checking: http://img.photobucket.com/albums/v90/fthaimike/Track%20Car/DCP_5701b.jpg
Would it be possible or more difficult if i extended mine a little bit more than usual to be able to use more standard type wheels? 7 x 15 ET30 & are the ball joint extenders? needed to compliment the rest, any specific type/size?
