8 valve engines - OEM, tuned + race outputs
Discussion in '8-valve' started by A.N. Other, Feb 18, 2011.
  1. Funky Diver Forum Member
    Darlington, UK
    Damn... please let me :p
  2. shaz8389
    shaz8389 Forum Junkie
    Callaway turbos on the yank company? Massively sought after on VW Vortex.
  3. Brian.G
    Brian.G Forum Member
    West of Ireland
    First table, last line, the AGG has 7mm stems hasn't it not?
  4. retrowhore Forum Member
    Nottinghamshire
  5. dan_gti2004 Forum Member
    Newbury
    Nice on Chris. good work there. Long live the mighty 8v :thumbup:
    Turbo specs now started in post 7 thanks to some fantastic contributions from Romain. Also loads more detailled Oettinger info added in the Tuner section, again thanks to Romain. The early engine dimensions are very different!
    Bizarrely, nothing so far on Callaway conversion outputs. Any links to period outputs?
    AGG valve stems: pass. I think we'd better double check 2E, AGG, ADY at the same time :thumbup:
    8AS to advise!
  7. danster Forum Addict
    The AGG engines I have come across use 7mm stems unlike the 2E which uses 8mm.
    Not sure on ADY.
  8. retrowhore Forum Member
    Nottinghamshire
    Callaway Turbo upgrade - original information from page 16 of the document here.
    I don't see any information about engine spec changes (i.e. compression ratios etc).
    I don't suppose its needed with a blow-through turbo setup. There weren't many changes on my Turbo Technics Fiesta as it was mainly an uprated headgasket, the turbo/oil feed setup and a cooler.
    Anyway, stage 1 kit 130bhp, stage 2 kit 185bhp
  9. R.b!n_16v Forum Member
    i have a ady and its has 7mm stems
  10. Brian.G
    West of Ireland
    Dumping these in here, Move if needs be:thumbup:
    1990GTIEngineering002.jpg 1990GTIEngineering003.jpg 1990GTIEngineering004.jpg 1990GTIEngineering005.jpg
    BG
    WAUOla likes this.
    Thanks Brian, all good here.
    I have this catalogue / similar somewhere, and that RE2000 crank is the fairly rare Holbay 94.5mm.
    I was discussing this with Romain and there's a theory it exists because we assume it has the 47.8mm big ends. Depending on when it was created, it may have beaten the 47.8mm journalled Oettinger 94.5mm crank to the market (there's a 46mm version preceding it).
    Otherwise no obvious reason why it exists, unless it came from the race side?
    I hope to have the race specs up soon on p1!
  12. romaingirardlamamy
    romaingirardlamamy Forum Member
    london
    Chris there might be some mistake
    On nearly all the 1600 cc racing engine you put they are fitted with 86.4 mm stroke but that will make them roughly 1700cc
    And on some of them you put 144 rods (not sure for this one)
    The other one is the drake wasn't from austria that was the graff fitted on button car I believe
  13. romaingirardlamamy
    london
    Sorry again supervee are dry sump too
  14. A.N. Other Banned after significant club disruption Dec 5th 2
    Crossflow engine spotted in Audi A4, ADP code, iron old-style block. 050 head. 74kW on boot sticker, chassis no WAUZZZ8DZTA203378.
  15. Bomber604
    Bomber604 Forum Member
    Shrewsbury
    8v PB engine built to Golf gti championship regs with "Man in the shed" re-con head & newman control cam = 130 bhp :thumbup:
  16. timo16v
    timo16v Paid Member Paid Member
    TSR Brands Hatch 2.0 8v BVH 202cam
    138.1 bhp @ 5600rpm
    146 lbft @ 4600rpm
    Mileage - 15,000mls
    Standard plenum with bosch AFM
    G60 injectors @ 3bar
    10 degrees ignition advance @ 2250rpm with CTS disconnected
    (Figures recorded @ Stealth Racing 25/03/2011)
  17. racer66 Forum Member
    1798 cc 8thou skimmed head iirc Ian Carvell/Crissle built engine, running webber 45's, Shrick Cams, wossner pistons.
    Ran at SRR on 07/04/11
    165 bhp, 150 lb ft
  18. A.N. Other Banned after significant club disruption Dec 5th 2
    A little more on the Callaway:
    The article itself was about the 920bhp, 254.76mph Callaway Corvette Sledgehammer.
  19. mk1. Forum Junkie
    1847cc perhaps with an 86.4 crank?
    http://www.clubgti.com/forum/showthread.php?t=228971
    Just grabbing the text in case it disappears:
