yaeh the 2 part numbers both come back to mk2 16v type dizzy so could just be early/late design is all. the hall sensor inside looks liek bog std think nowt special there. its just a case of are the trigger windows moved slightly vs oem and/or bigger/smaller. tricky one to measure if they are only moved a bit, probably need some real accurate measuring implements and possibly some match involving the use of pi
bog std 16v metering head there, air flcone could have been reprofiled though worth a look! if you got a std one somewhere compare it to the one ya got dizzy hall sensor looks liek a normal 16v unit, looks liek you caught it in time as the wire insulation looks ok. oil will eat into them after a while
Hey Jonny you know real stuff not just comp tech and part numbers lol You can't spell LIKE for toffee though lol
Aye oil kills the hall sensor over time if you don't watch The seals are fairly easy the get I used eriks but had to get ten to justify the price of the minimum order You'd be better getting from the place John used simply bearings Unless you have a place you deal with http://simplybearings.co.uk/shop/Products-Oil+Seals+and+Lubricants/c4747_4750/index.html
Yes use a couple of bearing suppliers and the place Jonny recommends is ten minutes away Guess you where right about the dizzy but could have been swopped at some time Won't know unless another RE2000 owner takes a look or I buy another RE2000 engine lol
I know my spelling is really bad, I sometimes think I may have mild dyslexia engien, anythign with 'ing' on the end and liek always the top 3 spelling fails edit: see! anythign. I didnt even write that one on purpose thank god for FireFox spellcheck, but fails still sneak in sometimes
Also good at visualising / problem solving and good with their hands generally Both my brother and I score very high on the dyslexia spectrum bordering on Aspergers hence we both lack good social skills lol I also score high on the psychopathic range means I get a bit obsessed sometimes hence 5 golfs 30 rc cars and a 100 scalextric cars plus loads of track sets lol My wife says I'm a bit obsessive lol but wishes I was a bit more obsessive about tidying like my mum lol
So moved this out of my mates garage tonight and put it into storage Actually looked better than I remembered so I must get it together in the not to distant future . So first I need to weld mot and sell the pinkster Second sort RE2000 number 2 for using Third rebuild race car engine Then I can maybe strip this for a full respray in tornado red ?
