Jolfa's FAQ / How to guide to bike carbs
Discussion in 'Throttle bodies & non-OEM ECUs' started by Jolfa, Dec 16, 2008.
  1. little16v New Member
    hello
    what other models of bike carbs can be added on a 1.8 KR with the same modifications like the zx9rs?
    thanks
  2. little16v New Member
    what other motorcycle carbs can i use?
    thanks
  3. mookie Forum Member
    Newcastle
    I'd all over this if I thought I could maintain affordable MPG - late 20's to early 30's?
    Anyone manage this on a carbed setup?
  4. shaz8389
    shaz8389 Forum Junkie
    I think you can get it if you tune them right. The noise is worth it...
  5. cdo1979 New Member
    Ive got aset 30mm carbs off a 600 yamaha will they work
  6. Rusty Dan Forum Member
    What is the deal with wiring from the ECU, what is needed and not needed anymore with the conversion? Just a thought for those that want to tidy their bay up a wee bit.
    Cheers
    Rusty
  7. K-Jet New Member
    So, do you run the in-tank pump AND the bike pump, or just run the bike pump and draw fuel over the stationary in-tank pump?
  8. Rusty Dan Forum Member
    From what I have read you just replace the fuel pump with the bike pump or facet redtop and leave the in tank pump in.
  9. Jolfa
    Jolfa Forum Junkie
    Queenstown - New Zealand
    Are people just looking at the pictures or what?! All these questions are answered in the first post ffs, read it!
  10. K-Jet New Member
    Okay okay, so use the in-tank pump to feed the bike pump then... :thumbup:
  11. booboo Forum Member
    facit redtop pumps are cool, when i installed a holley 750cfm carb on my tbird i had to get 7psi of fuel and they pump out around 7.5 . i didnted get a regulator to lower it , all i did was adjust the floats on the carb itself. surely bikew carbs must have this sort of thing ????? and with that installed i went from 17-23mpg down to 10 at its best lol anyone thought of using a carb off a more chunky bike rather than a superbike like a r1 you could get one off a big harley as would have different sort of power maybe????????????
  12. Jolfa
    Jolfa Forum Junkie
    Yes :)
    Plus if your pump happens to pack up, the lift pump will be enough to feed the carbs by itself (as I found out) but I wouldn't just use the lift pump by itself otherwise...
    booboo, I can't really make much sense of your post, but the easiest, cheapest and best way to feed bike carbs is with a bike pump - they run at the right pressure and stop pumping once the carbs are full too :thumbup:
  13. G60KG
    G60KG Forum Member
    at work 'working'
    Would this setup work on a Corrado 16v with a 9a and ke motronic ecu etc..
  14. wippy748s Forum Member
    i put some on my 8v a few years ago, i used yam r6 carbs and didnt use a pressure regulator at all, the carbs have an inlet and return to the tank and just the pressure running through the inlet was enough, here is a little vid
    http://www.youtube.com/watch?v=kAdOH-M8rDk
  15. Jolfa
    Jolfa Forum Junkie
    Can't watch the vid, but R6 carbs are the same as R1 carbs (I've had a couple of sets) and as per any other set of bike carbs I've had they only have a fuel in, no return.
    You didn't do what I've seen so many people try and do did you and just plumb the fuel into the breathers or coolant channels? [><]
    No idea on the Corrado question. If the spark management is seperate from the standard fuel gubbins there'll be no problem. If it's in some way linked I don't have a clue [:p]
  16. gnasher New Member
    in the early stages of doing this to my 16v just out of interest jolfa ive been led to believe that only 1998-2001 r1 carbs can be used?do you know if this is true,a friend of a friend as got some 2007 r1 carbs going cheap dya know if id have probs fitting these:thumbup:
  17. Jolfa
    Jolfa Forum Junkie
    I've yet to see a set of bike carbs that aren't suitable, my mate has some from the 80's by the looks of things from mystery bike and they're fine.
    I think the difference with newer carbs is that they have a TPS, which isn't essential unless you're using some kind of aftermarket management :)
  18. gnasher New Member
    oh rite i see,ill have at look at these hes got then,cheers
  19. gnasher New Member
    sorry to bug you again jolfa checked these carbs out this morning there mint and couldnt turn them down for the price,like you said theve got a tps on them,do you no if i just leave it unplugged?im gunna be running the standard 16v dizzy ecu etc:thumbup:
  20. jamez Forum Member
    Netherlands
    I tought that post 2001 R1's didn't use carbs but trottle bodies ?
